Aller au contenu principal
Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement, Lower Case: étape 1, image 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: étape 2, image 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement, USB/SD Card Hub: étape 3, image 1 de 2 Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement, USB/SD Card Hub: étape 3, image 2 de 2
    • Remove the 4mm screw with a JIS #0 screwdriver.
  4. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: étape 4, image 1 de 1
    • Remove the ribbon cable.
  5. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: étape 5, image 1 de 1
    • Remove the existing USB hub and replace it with the new hub.
Elijah Ellis
Membre depuis le 11/08/18
616 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 328
