Aller au contenu principal
Lenovo IdeaPad Flex 5-1470 Speaker Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Back Panel: étape 1, image 1 de 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: étape 2, image 2 de 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Battery: étape 3, image 1 de 1
    • Remove the two 3.6 mm Phillips #00 battery screws located in the lower left corner of the device.
  4. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: étape 4, image 1 de 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: étape 4, image 2 de 2
    • Gently unplug the multi-colored cable connecting the battery to the motherboard.
    • Remove the battery from the laptop.
  5. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Speaker: étape 5, image 1 de 1
    • Remove the two speakers from their compartment. The speakers are held in the bottom corners of the device.
  6. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: étape 6, image 1 de 2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: étape 6, image 2 de 2
    • Carefully unplug two wired connections from the motherboard using nylon tip reverse tweezers.
Ryan Beste
Membre depuis le 01/23/20
141 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S2-G5, White Winter 2020 Membre de l'équipe Cal Poly, Team S2-G5, White Winter 2020
CPSU-WHITE-W20S2G5
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 22
Total : 1,120
