Introduction
If your Lenovo IdeaPad Flex 5-1470 (Model Name: 80XA Model Number: 80XA0001US) is refusing to connect to wireless connections and your wireless network adapter has stopped working, simply follow this guide. The wireless network adapter is a small chip located in the top right corner of the device that allows the laptop to successfully connect to Wi-Fi connections.
Ce dont vous avez besoin
Use the reverse tweezers to carefully unplug the two wired connections.
Un commentaire
Thank you!
My problem now is the replacement of the tiny male connectors which hooks onto the chip. They are shown in the last image above at the end of the white wire!
I do not know where to get them, given that mine were broken off.
I would deeply appreciate your help in identifying this type of connectors and locating a sources!
Apart from that, as usual, an excellent and up-to-the-point review.
Thank you again.
Dr. Khaled Bizri,
(650) 796 5864
Khaled.Bizri@GMail.com
