Aller au contenu principal
Lenovo IdeaPad Flex 6-14IKB RAM Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, Base Cover: étape 1, image 1 de 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, RAM: étape 3, image 1 de 1
    • Use the plastic opening tool to pry the protective cover off of the RAM.
  4. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: étape 4, image 1 de 2 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: étape 4, image 2 de 2
    • Unfasten the metal clips that secure the RAM.
  5. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: étape 5, image 1 de 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: étape 5, image 2 de 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: étape 5, image 3 de 3
    • Remove the RAM from its slot on the motherboard.
Ryan Reish
Membre depuis le 01/09/22
411 Réputation
3 tutoriels rédigés
Un commentaire
Thank you so much
Ayham Ka - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 32
Total : 705
