Aller au contenu principal
Lenovo IdeaPad G50-45 DVD Drive Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad G50-45 DVD Drive Replacement, DVD Drive: étape 1, image 1 de 1
    • First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
    • To avoid losing the small screws, put them in a container.
  2. Lenovo IdeaPad G50-45 DVD Drive Replacement: étape 2, image 1 de 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: étape 2, image 2 de 2
    • To remove the panel on the laptop, gently slide the panel away from the battery.
    • Make sure to slide the panel away before you lift to keep the panel from breaking.
    • Lift up the panel and place it to the side.
  3. Lenovo IdeaPad G50-45 DVD Drive Replacement: étape 3, image 1 de 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: étape 3, image 2 de 2
    • Remove the indicated screw holding the DVD Drive.
    • To avoid losing the screw, place it in the same container used to hold the other three screws.
  4. Lenovo IdeaPad G50-45 DVD Drive Replacement: étape 4, image 1 de 1
    • Push the now-free tab towards the DVD Drive using a flathead screwdriver.
    • Do not pry up the now-free tab.
  5. Lenovo IdeaPad G50-45 DVD Drive Replacement: étape 5, image 1 de 1
    • Lastly, pull out the DVD Drive; it should come out easily.
6 autres ont terminé cette réparation.
Saulo Gomes
Membre depuis le 10/26/15
601 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Membre de l'équipe UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 19
Total : 8,470
