Introduction
This guide will help you replace your DVD Drive on your Lenovo Ideapad G50-45. You might need this repair if your DVD Drive has failed. Please reference the troubleshooting page, or your product manual, to determine if this has occurred.
Before starting this repair, you should remove your battery. Please follow this battery removal guide.
You should also have
- A flathead screwdriver
- A Phillips #2 screwdriver
- A replacement DVD Drive
- A small container to hold screws
Keep in mind to be gentle when removing and replacing any screws. They could strip easily.
Good luck and happy fixing!
Ce dont vous avez besoin
First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
To avoid losing the small screws, put them in a container.
6 autres ont terminé cette réparation.
