Aller au contenu principal
Lenovo IdeaPad S10-2 Battery Replacement
  1. Lenovo IdeaPad S10-2 Battery Replacement, Battery: étape 1, image 1 de 2 Lenovo IdeaPad S10-2 Battery Replacement, Battery: étape 1, image 2 de 2
    • Start with the laptop upside down and the bottom panel facing up.
    • Identify the two switches located near the battery compartment. These two switches are used to remove the battery.
  2. Lenovo IdeaPad S10-2 Battery Replacement: étape 2, image 1 de 2 Lenovo IdeaPad S10-2 Battery Replacement: étape 2, image 2 de 2
    • Firmly push the two switches inward and toward each other.
    • As you push, simultaneously lift the battery upward to release it from its port.
  3. Lenovo IdeaPad S10-2 Battery Replacement: étape 3, image 1 de 1
    • Remove the battery.
    • Align the new battery with the compartment.
    • Push the battery into place until you hear a click, indicating it is secured.
To re-insert the battery follow the instructions in reverse order.
You’ve successfully replaced the battery on your Lenovo IdeaPad S10-2! Regular maintenance, such as battery calibration, will help prolong the life of your new battery. For additional help, refer to Lenovo’s support resources.
Faylin Riemer
Membre depuis le 10/13/15
101 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 1-7, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-7, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G7
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 24
Total : 2,035
