Aller au contenu principal
Lenovo IdeaPad S10-2 Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: étape 1, image 2 de 2
    • Start with laptop closed.
    • Turn laptop over so the back panel is visible, as shown in the second image.
    • Remove the two 40 mm Phillips screws using a Phillips J0 head screwdriver.
  2. Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 2, image 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 2, image 2 de 2
    • Remove both 40 mm Phillips screws using a Phillips J0 head screwdriver.
    • Remove the back panel and set it aside.
  3. Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 3, image 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 3, image 2 de 2
    • Remove the 40 mm screw using a Phillips J0 head screwdriver.
  4. Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 4, image 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 4, image 2 de 2
    • After removing the screw, carefully wedge the flat end of a spudger in the spacing to remove the hard drive from the port.
    • Pry the hard drive out of its port.
    • Push the wedged end of the spudger out as indicated by the action shots.
  5. Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 5, image 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 5, image 2 de 2
    • Carefully lift the hard drive enclosure to remove it from the laptop.
    • The enclosure is the metal case holding the actual hard drive. You must remove the metal case in order to replace the hard drive.
  6. Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 6, image 1 de 3 Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 6, image 2 de 3 Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 6, image 3 de 3
    • The hard drive enclosure has four 40 mm screws keeping the hard drive in place.
    • Remove the four 40 mm screws with a Phillips J0 head screwdriver.
  7. Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 7, image 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: étape 7, image 2 de 2
    • Slide the hard drive out of the enclosure.
    • The new hard drive can be inserted into the same enclosure.
Anthony
Membre depuis le 10/13/15
282 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 1-7, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-7, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G7
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 14
Total : 9,596
