Aller au contenu principal
Lenovo IdeaPad S10-2 Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad S10-2 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Rotate the laptop so the back side is facing you.
    • From this side, you should be able to see both of the gaps where the two plastic materials meet.
  2. Lenovo IdeaPad S10-2 Keyboard Replacement: étape 2, image 1 de 2 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 2, image 2 de 2
    • Wedge the nylon or metal spudger inside the gap and pry open the two plastic parts.
  3. Lenovo IdeaPad S10-2 Keyboard Replacement: étape 3, image 1 de 2 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 3, image 2 de 2
    • Open the laptop.
    • Place the nylon or metal spudger under the top half that is loose and pull up to pry it open.
  4. Lenovo IdeaPad S10-2 Keyboard Replacement: étape 4, image 1 de 3 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 4, image 2 de 3 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 4, image 3 de 3
    • Pull up on the loose component to remove.
    • As you lift the keyboard, you should be able to see a strip connected to the laptop.
  5. Lenovo IdeaPad S10-2 Keyboard Replacement: étape 5, image 1 de 3 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 5, image 2 de 3 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 5, image 3 de 3
    • Remove the strip by pulling both sides of the blue strip out.
    • Lift and remove the keyboard from the laptop.
2 autres ont terminé cette réparation.
Mary
Membre depuis le 10/13/15
132 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 1-7, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-7, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G7
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 3,261
