Aller au contenu principal
Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement, Wireless WiFi Card: étape 1, image 1 de 1
    • The tools needed are the blunt edge of the spudger and a Phillips J0 head screwdriver.
    • Ensure your device is powered off before continuing.
  2. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 2, image 1 de 2 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 2, image 2 de 2
    • Turn the laptop over to begin.
    • Remove the two 40 mm screws with a Phillips J0 head screwdriver.
  3. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 3, image 1 de 2 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 3, image 2 de 2
    • The WiFi card is found near the bottom of the panel.
  4. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 4, image 1 de 3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 4, image 2 de 3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Do not use the metal precision tweezers as shown.
    • Using the blunt end of the spudger, wedge the spudger beneath the connector and pull straight up to remove the white wire. Repeat to remove the black connector.
    • When reinstalling these U.FL connectors, hold the connector in place and gently push down. The connector should snap into place like a button.
  5. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 5, image 1 de 3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 5, image 2 de 3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: étape 5, image 3 de 3
    • Remove the two 40 mm screws using a Phillips J0 head screwdriver.
    • Lift and remove the WiFi card.
Lucy Mendez
Membre depuis le 10/10/15
155 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 1-7, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-7, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G7
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 20
Total : 2,263
