Introduction
Use this guide to replace a faulty cooling fan of a Lenovo IdeaPad S210 Touch. Replacing the cooling fan can alleviate problems caused by overheating such as unexpected shutdowns and shortened battery life. The operation is a simple process that involves a #0 Phillips screwdriver and the removal of screws that hold the fan in place.
Before beginning the removal process, ensure your device is turned off and disconnected from power supplies.
Ce dont vous avez besoin
Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
If any tape is present, remove all tape from the area within the red area.
