Introduction
If you need to replace the hard drive, follow this guide. For this guide you will need Phillips #0 screwdriver, from the iFixit tool kit to remove the back case. You will need a plastic spudger to remove the casing.
Ce dont vous avez besoin
Turn your computer over so the back is face up.
Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
The battery cover will then pop up allowing you access to the battery.
Remove the five 6mm Phillips #0 screws from the back panel.
Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
Remove the three 6mm Phillips #0 screws from under the battery.
3 autres ont terminé cette réparation.
