Aller au contenu principal
Lenovo IdeaPad S400 Touch RAM Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad S400 Touch RAM Replacement, Battery: étape 1, image 1 de 3 Lenovo IdeaPad S400 Touch RAM Replacement, Battery: étape 1, image 2 de 3 Lenovo IdeaPad S400 Touch RAM Replacement, Battery: étape 1, image 3 de 3
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch RAM Replacement, RAM: étape 2, image 1 de 3 Lenovo IdeaPad S400 Touch RAM Replacement, RAM: étape 2, image 2 de 3 Lenovo IdeaPad S400 Touch RAM Replacement, RAM: étape 2, image 3 de 3
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to the battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch RAM Replacement: étape 3, image 1 de 1
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch RAM Replacement: étape 4, image 1 de 3 Lenovo IdeaPad S400 Touch RAM Replacement: étape 4, image 2 de 3 Lenovo IdeaPad S400 Touch RAM Replacement: étape 4, image 3 de 3
    • Push the metal arms away from the RAM.
    • The RAM should pop up.
    • Pull the RAM out.
2 autres ont terminé cette réparation.
Max Hoyle
Membre depuis le 02/12/19
538 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 16
Total : 776
