Aller au contenu principal
Lenovo IdeaPad U310 Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad U310 Battery  Replacement, Battery: étape 1, image 1 de 1
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Battery  Replacement: étape 2, image 1 de 1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Battery  Replacement: étape 3, image 1 de 2 Lenovo IdeaPad U310 Battery  Replacement: étape 3, image 2 de 2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Battery  Replacement: étape 4, image 1 de 2 Lenovo IdeaPad U310 Battery  Replacement: étape 4, image 2 de 2
    • Unplug the Battery from the circuit board by carefully prying the connector from its housing.
  5. Lenovo IdeaPad U310 Battery  Replacement: étape 5, image 1 de 2 Lenovo IdeaPad U310 Battery  Replacement: étape 5, image 2 de 2
    • Remove the 5.6 mm Screw with the PH1 screwdriver.
    • Remove the 4.6 mm screws with the PH1 screwdriver.
  6. Lenovo IdeaPad U310 Battery  Replacement: étape 6, image 1 de 2 Lenovo IdeaPad U310 Battery  Replacement: étape 6, image 2 de 2
    • Lift the strip tape away from the battery, being careful not to completely remove it.
  7. Lenovo IdeaPad U310 Battery  Replacement: étape 7, image 1 de 1
    • Remove the battery by lifting up and away from device.
2 autres ont terminé cette réparation.
Andrew Capra
Membre depuis le 09/28/16
388 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 16
Total : 5,421
