Introduction
The fan keeps the components in your computer cool. It expels heat by sucking in cold air from outside of the case and blowing it across the warm heatsink. A broken fan can lead to components overheating and failing.
Outils
Pièces
Aucune pièce spécifiée.
Unscrew the three screws on the bottom of the laptop that have small keyboard logos next to them using a PH1 screwdriver. These screws are 5.8mm long.
Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
Unscrew the nine screws that are around the edge of the laptop using a PH00 screwdriver. These screws are 5.7mm long.
Unscrew the remaining two M2.5X3 screws that were under the battery using a PH1 screwdriver. These screws are 3.7mm long.
Unscrew the three M2X3 screws that were under the hard drive using a PH1 screwdriver. These screws are 3.7mm long.
2 autre(s) ont terminé cette réparation.
