Aller au contenu principal
Lenovo IdeaPad U350 RAM Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad U350 RAM Replacement, RAM: étape 1, image 1 de 1
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are 4.7mm long with a head diameter of 3.68mm.
    • The screws are attached to the panel. When unscrewing be sure to stop when you hear a click.
  2. Lenovo IdeaPad U350 RAM Replacement: étape 2, image 1 de 1
    • Gently lift the back panel from the side closest to the battery and remove panel
  3. Lenovo IdeaPad U350 RAM Replacement: étape 3, image 1 de 1
    • Push retention clips outward and then gently slide out of slot
  4. Lenovo IdeaPad U350 RAM Replacement: étape 4, image 1 de 1
    • Remove white and black wires to make room to remove the second RAM module.
  5. Lenovo IdeaPad U350 RAM Replacement: étape 5, image 1 de 1
    • Just like RAM Module 1, push retention clips outward and gently slide out the RAM Module.
    • When re-installing RAM modules, be sure to insert them at a 45 degree angle. This is the same angle that they should pop up to after the retention clips are pushed outward.
James Morizzo
Membre depuis le 09/29/14
496 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-4, Hickman Fall 2014
USFT-HICKMAN-F14S1G4
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 954
