Aller au contenu principal
Lenovo IdeaPad U410 Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: étape 1, image 1 de 2 Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: étape 1, image 2 de 2
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Battery Replacement: étape 2, image 1 de 3 Lenovo IdeaPad U410 Battery Replacement: étape 2, image 2 de 3 Lenovo IdeaPad U410 Battery Replacement: étape 2, image 3 de 3
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Battery Replacement, Battery: étape 3, image 1 de 1
    • Make sure your computer is turned off.
    • Lift the back panel away from you.
    • Locate the battery in the bottom right corner.
  4. Lenovo IdeaPad U410 Battery Replacement: étape 4, image 1 de 1
    • Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
  5. Lenovo IdeaPad U410 Battery Replacement: étape 5, image 1 de 3 Lenovo IdeaPad U410 Battery Replacement: étape 5, image 2 de 3 Lenovo IdeaPad U410 Battery Replacement: étape 5, image 3 de 3
    • Locate the small rectangle shaped connector to the left of your battery.
    • Use your fingers to gently detach the white connector.
Alysia Mcafee
Membre depuis le 09/18/18
107 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 848
