Aller au contenu principal
Lenovo IdeaPad U410 Screen Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad U410 Screen Replacement, Screen: étape 1, image 1 de 2 Lenovo IdeaPad U410 Screen Replacement, Screen: étape 1, image 2 de 2
    • Make sure your laptop is turned off before disassembling.
    • Power off the laptop.
    • Using the metal spudger, gently pry off the black trim around the screen.
    • Metal spudger can be used, but using your hand will prevent the screen and the plastic border from any damage.
  2. Lenovo IdeaPad U410 Screen Replacement: étape 2, image 1 de 2 Lenovo IdeaPad U410 Screen Replacement: étape 2, image 2 de 2
    • Remove the six 3 mm Phillips #1 screws holding the screen to the laptop.
    • Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
  3. Lenovo IdeaPad U410 Screen Replacement: étape 3, image 1 de 3 Lenovo IdeaPad U410 Screen Replacement: étape 3, image 2 de 3 Lenovo IdeaPad U410 Screen Replacement: étape 3, image 3 de 3
    • Lower LCD screen onto the keyboard.
    • Find the gold connector on the bottom of the LCD panel.
    • Gently grab the connector on both sides and pull the connector straight out.
    • Connector cable is very fragile. Use the least amount of force possible.
Edric An
Membre depuis le 09/18/18
433 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 1,481
