Aller au contenu principal
Lenovo IdeaPad U430 Touch Memory Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad U430 Touch Memory Replacement, Bottom Cover: étape 1, image 1 de 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Memory Replacement: étape 3, image 1 de 2 Lenovo IdeaPad U430 Touch Memory Replacement: étape 3, image 2 de 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Memory Replacement, Memory: étape 4, image 1 de 2 Lenovo IdeaPad U430 Touch Memory Replacement, Memory: étape 4, image 2 de 2
    • Press down and out on the topside of the clips holding the memory in place.
  4. Lenovo IdeaPad U430 Touch Memory Replacement: étape 5, image 1 de 1
    • Once the clips are free, pull the topside of the memory up, and then remove it from the slot.
Patrick Ripkey
Membre depuis le 02/28/17
627 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G6, Nance Spring 2017 Membre de l'équipe USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
3 membres
15 tutoriels rédigés
Un commentaire
What is the maximum RAM this machine will support?
Tom Steger - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 2,120
