Aller au contenu principal
Lenovo IdeaPad U430 Touch Speaker Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad U430 Touch Speaker Replacement, Bottom Cover: étape 1, image 1 de 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Speaker Replacement: étape 3, image 1 de 2 Lenovo IdeaPad U430 Touch Speaker Replacement: étape 3, image 2 de 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Speaker Replacement, Speaker: étape 4, image 1 de 1
    • Disconnect the speaker cable connectors from the motherboard and/or USB board.
  4. Lenovo IdeaPad U430 Touch Speaker Replacement: étape 5, image 1 de 2 Lenovo IdeaPad U430 Touch Speaker Replacement: étape 5, image 2 de 2
    • Unscrew the two 6.5mm screws from each speaker with a PH1 Phillips head screwdriver.
  5. Lenovo IdeaPad U430 Touch Speaker Replacement: étape 6, image 1 de 2 Lenovo IdeaPad U430 Touch Speaker Replacement: étape 6, image 2 de 2
    • Remove and replace the speaker.
Patrick Ripkey
Membre depuis le 02/28/17
627 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G6, Nance Spring 2017 Membre de l'équipe USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
3 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 11
Total : 557
