Aller au contenu principal
Lenovo IdeaPad U430 Touch Trackpad Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad U430 Touch Trackpad Replacement, Bottom Cover: étape 1, image 1 de 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Trackpad Replacement: étape 3, image 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement: étape 3, image 2 de 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Trackpad Replacement, Battery: étape 4, image 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement, Battery: étape 4, image 2 de 2
    • Remove the five 2.8 mm #1 Phillips head screws that hold down the battery pack.
  4. Lenovo IdeaPad U430 Touch Trackpad Replacement: étape 5, image 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
    • When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
    • The battery connector is very tight fitting, you may need to use a metal spudger in order to get the connector out far enough.
  5. Lenovo IdeaPad U430 Touch Trackpad Replacement: étape 6, image 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement: étape 6, image 2 de 2
    • Once the battery is disconnected, lift up on the front of the battery and remove it from the laptop body.
  6. Lenovo IdeaPad U430 Touch Trackpad Replacement, Trackpad: étape 7, image 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement, Trackpad: étape 7, image 2 de 2
    • Remove the two 2.8 mm screws attached to the trackpad using the Phillips #1 screwdriver.
    • Detach the zif ribbon labeled "TP" and "MB" at the "MB" end.
  7. Lenovo IdeaPad U430 Touch Trackpad Replacement: étape 8, image 1 de 1
    • Grasping one of the screw brackets, gently lift the trackpad out of its frame.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 310
