Aller au contenu principal
Lenovo IdeaPad U450 Screen Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad U450 Screen Replacement, Battery: étape 1, image 1 de 1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Screen Replacement: étape 2, image 1 de 1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Screen Replacement: étape 3, image 1 de 1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Screen Replacement: étape 4, image 1 de 1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Screen Replacement, Screen: étape 5, image 1 de 1
    • Open the laptop.
  6. Lenovo IdeaPad U450 Screen Replacement: étape 6, image 1 de 1
    • Remove the four 7mm phillips head screws in the corners of the screen with a Phillips #00 Screwdriver.
  7. Lenovo IdeaPad U450 Screen Replacement: étape 7, image 1 de 1
    • Pry the screen out of the tabs with a spudger.
  8. Lenovo IdeaPad U450 Screen Replacement: étape 8, image 1 de 1
    • Remove the four 7mm phillips head screws located beneath the screen.
  9. Lenovo IdeaPad U450 Screen Replacement: étape 9, image 1 de 1
    • Pop out the connector that links the screen to the motherboard.
  10. Lenovo IdeaPad U450 Screen Replacement: étape 10, image 1 de 1
    • Pop the new screen into the connector.
Rachel L Rodrigues
Membre depuis le 03/21/17
464 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S7-G1, Julie Spring 2017 Membre de l'équipe UMass Dartmouth, Team S7-G1, Julie Spring 2017
UMASSD-JULIE-S17S7G1
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 216
