Introduction
This is a step-by-step guide on how to replace the hard drive inside Lenovo IdeaPad U530 Touch laptop.
Symptoms related to hard drive failure are as follows:
- blue screens,
- loud scratching or clicking noises,
-and a “file not found” error when opening a file.
Make sure to wear gloves when operating inside the device.
Ce dont vous avez besoin
Remove the back panel by removing all screws. Use a PH000 screwdriver head.
Make sure to also remove the hinge screws.
Remove two 3 mm screws connecting the hard drive to the computer base using a JIS #1 screwdriver.
Detach the connection from the hard drive to the motherboard.
Remove the hard drive from the laptop.
