Aller au contenu principal
Lenovo IdeaPad U530 Touch RAM Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad U530 Touch RAM Replacement, Battery: étape 1, image 1 de 3 Lenovo IdeaPad U530 Touch RAM Replacement, Battery: étape 1, image 2 de 3 Lenovo IdeaPad U530 Touch RAM Replacement, Battery: étape 1, image 3 de 3
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch RAM Replacement: étape 2, image 1 de 2 Lenovo IdeaPad U530 Touch RAM Replacement: étape 2, image 2 de 2
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch RAM Replacement: étape 3, image 1 de 1
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch RAM Replacement: étape 4, image 1 de 2 Lenovo IdeaPad U530 Touch RAM Replacement: étape 4, image 2 de 2
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch RAM Replacement: étape 5, image 1 de 1
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch RAM Replacement: étape 6, image 1 de 1
    • Simply lift the battery out of the computer, and acquire a replacement.
  7. Lenovo IdeaPad U530 Touch RAM Replacement, RAM: étape 7, image 1 de 2 Lenovo IdeaPad U530 Touch RAM Replacement, RAM: étape 7, image 2 de 2
    • Carefully pull on the tabs on each side of the RAM to release it from its slot
    • Carefully pull the old RAM out of the laptop.
Riki
Membre depuis le 09/20/21
73 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 7
Total : 319
