Aller au contenu principal
Lenovo IdeaPad Y410p Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Y410p Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Hard Drive Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Y410p Hard Drive Replacement: étape 2, image 2 de 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Hard Drive Replacement: étape 3, image 1 de 2 Lenovo IdeaPad Y410p Hard Drive Replacement: étape 3, image 2 de 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Hard Drive Replacement, Hard Drive: étape 4, image 1 de 3 Lenovo IdeaPad Y410p Hard Drive Replacement, Hard Drive: étape 4, image 2 de 3 Lenovo IdeaPad Y410p Hard Drive Replacement, Hard Drive: étape 4, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the eight 8mm screws that fasten the bottom cover.
    • Lift bottom cover off using a metal spudger and set it aside.
  5. Lenovo IdeaPad Y410p Hard Drive Replacement: étape 5, image 1 de 3 Lenovo IdeaPad Y410p Hard Drive Replacement: étape 5, image 2 de 3 Lenovo IdeaPad Y410p Hard Drive Replacement: étape 5, image 3 de 3
    • If you intend to reuse this hard drive, be careful removing it as hard impacts may damage the device.
    • Using the Phillips #0 screwdriver, remove the two 3mm screws at the end of the hard drive bracket.
    • Slide the hard drive out of its seat.
Nick Torres
Membre depuis le 09/18/18
580 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 24
Total : 750
