Aller au contenu principal
Lenovo IdeaPad Y410p Ram Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Y410p Ram Replacement, Battery: étape 1, image 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Ram Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Y410p Ram Replacement: étape 2, image 2 de 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Ram Replacement: étape 3, image 1 de 2 Lenovo IdeaPad Y410p Ram Replacement: étape 3, image 2 de 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Ram Replacement, Ram: étape 4, image 1 de 3 Lenovo IdeaPad Y410p Ram Replacement, Ram: étape 4, image 2 de 3 Lenovo IdeaPad Y410p Ram Replacement, Ram: étape 4, image 3 de 3
    • Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
    • Lift the bottom cover off using a metal spudger and set it aside.
  5. Lenovo IdeaPad Y410p Ram Replacement: étape 5, image 1 de 2 Lenovo IdeaPad Y410p Ram Replacement: étape 5, image 2 de 2
    • Simultaneously pull apart both clips that are holding the RAM module down.
    • When the RAM module is released carefully pull it out.
  6. Lenovo IdeaPad Y410p Ram Replacement: étape 6, image 1 de 2 Lenovo IdeaPad Y410p Ram Replacement: étape 6, image 2 de 2
    • There is a second ram module under the first one.
    • Repeat Step 5 with lower Ram module.
Nick Torres
Membre depuis le 09/18/18
580 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 19
Total : 869
