Aller au contenu principal
Lenovo IdeaPad Y410p Screen Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Y410p Screen Replacement, Battery: étape 1, image 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Screen Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Y410p Screen Replacement: étape 2, image 2 de 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Screen Replacement: étape 3, image 1 de 2 Lenovo IdeaPad Y410p Screen Replacement: étape 3, image 2 de 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Screen Replacement, Screen: étape 4, image 1 de 2 Lenovo IdeaPad Y410p Screen Replacement, Screen: étape 4, image 2 de 2
    • Using the metal spudger, pry the screen cover off from all sides.
    • Carefully lift the screen cover up and outwards.
    • Place the screen cover aside.
  5. Lenovo IdeaPad Y410p Screen Replacement: étape 5, image 1 de 3 Lenovo IdeaPad Y410p Screen Replacement: étape 5, image 2 de 3 Lenovo IdeaPad Y410p Screen Replacement: étape 5, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws from each corner of the screen.
    • Carefully lift the screen up and place it face down on the keyboard.
    • A thick cord connects the bottom of the screen to the computer. Do not tug or remove this cord from the computer.
  6. Lenovo IdeaPad Y410p Screen Replacement: étape 6, image 1 de 2 Lenovo IdeaPad Y410p Screen Replacement: étape 6, image 2 de 2
    • Remove the adhesive tape from the small rectangular connector at the bottom of the screen.
    • Carefully pull the wire connector from the screen connector.
    • Remove the screen.
2 autres ont terminé cette réparation.
Nick Torres
Membre depuis le 09/18/18
580 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 364
