Ce dont vous avez besoin
Turning over the laptop, look for two tabs that are located by the fan
Push these tabs to the opposite sides (left to right and vise versa.) when done correctly, you should see at least one tab with a red indicator on the right
Carefully remove the battery by slowly pulling the battery towards you, the battery should come out with no force
Take a JI head screwdriver and remove the nine screws holding the back panel down.
When done correctly, the back panel should come off with little difficulty. If there is resistance, make sure that all screws are removed
3 autres ont terminé cette réparation.
