Aller au contenu principal
Lenovo IdeaPad Y580-2099 Daughterboard Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Battery: étape 1, image 1 de 1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 2, image 2 de 2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Keyboard: étape 3, image 1 de 2 Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Keyboard: étape 3, image 2 de 2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 4, image 1 de 1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 5, image 1 de 2 Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 5, image 2 de 2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Daughterboard: étape 6, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the 16 screws highlighted. There are 12 M2.5 x 8 mm long screws, and 4 M2 x 2 mm long screws.
    • Use a Phillips #0 screwdriver to remove the 10 mm screw (highlighted in orange) that secures the disc drive.
    • Quickly survey and make sure all screws on the back panel are removed from the device.
    • Some of the screws may have been removed in previous steps.
  7. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 7, image 1 de 1
    • Carefully slide the disc drive out.
  8. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 8, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the three M2 x 3 mm long screws circled in red.
  9. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 9, image 1 de 1
    • Lift open the top panel carefully as there are wire cables secured to the motherboard.
  10. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 10, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • After locating the cable holding the top panel in place, carefully unhook the handle using precision tweezers.
    • Carefully remove the top plate.
  11. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 11, image 1 de 1
    • Now that the top plate is removed, locate the daughter board. (Highlighted in Red).
  12. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 12, image 1 de 1
    • Use a plastic spudger or precision tweezers to carefully unhook the daughterboard cables.
  13. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 13, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the two M2.5 x 3 mm long screws that secure the daughterboard.
  14. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: étape 14, image 1 de 1
    • Check and make sure all screws and cable wires are detached before attempting to remove the daughterboard.
    • Carefully remove the daughterboard.
Jeryn Fast
Membre depuis le 04/12/22
421 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Beck Spring 2022 Membre de l'équipe IUPUI, Team 1-1, Beck Spring 2022
IUPUI-BECK-S22S1G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 139
