Aller au contenu principal
Lenovo IdeaPad Y580-2099 Speaker Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Y580-2099 Speaker Replacement, Battery: étape 1, image 1 de 1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 2, image 1 de 2 Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 2, image 2 de 2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Speaker Replacement, Keyboard: étape 3, image 1 de 2 Lenovo IdeaPad Y580-2099 Speaker Replacement, Keyboard: étape 3, image 2 de 2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 4, image 1 de 1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 5, image 1 de 2 Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 5, image 2 de 2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: étape 6, image 1 de 3 Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: étape 6, image 2 de 3 Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: étape 6, image 3 de 3
    • Flip laptop back over and unscrew the disc drive screw.
    • Remove the disc drive.
    • Unscrew all of the screws on the back of the device.
  7. Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 7, image 1 de 3 Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 7, image 2 de 3 Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 7, image 3 de 3
    • Flip the device over.
    • Unplug the two wires, as shown in the images.
    • Lift up on the keyboard bezel.
    • The bezel should come up easy, if not go back and make sure all screws have been removed.
  8. Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 8, image 1 de 2 Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 8, image 2 de 2
    • Unscrew the screws on the motherboard.
    • Disconnect the three connectors the two black and one white.
  9. Lenovo IdeaPad Y580-2099 Speaker Replacement: étape 9, image 1 de 1
    • Carefully lift up the motherboard.
    • Unplug the wires underneath the motherboard.
    • Be careful not to rip the wires underneath the motherboard while lifting it up.
  10. Lenovo IdeaPad Y580-2099 Speaker Replacement, Speakers: étape 10, image 1 de 2 Lenovo IdeaPad Y580-2099 Speaker Replacement, Speakers: étape 10, image 2 de 2
    • Unscrew the two screws in each of the corners of the speakers.
    • Remove the speakers.
Lauren
Membre depuis le 09/25/17
481 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 6
30 derniers jours : 11
Total : 1,449
