Aller au contenu principal
Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement, Wi-Fi Card: étape 1, image 1 de 1
    • Make sure the laptop is powered off and disconnected from the charger.
    • Flip the laptop upside down so that the bottom faces up.
  2. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Place your thumbs on each side of the laptop and slide the tabs into the unlock position.
  3. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Once tabs are in the unlock position, carefully slide the battery out of the compartment.
  4. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: étape 4, image 1 de 1
    • Use a Phillips #0 screwdriver to unscrew and remove the two 8 mm screws (highlighted in red) that secure the back panel in place.
  5. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Gently slide & pull the panel off the device.
  6. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: étape 6, image 1 de 2 Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: étape 6, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that secure the Wi-Fi card in place.
  7. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: étape 7, image 1 de 1
    • Gently unplug the two coaxial antenna cables clasped to the Wi-Fi card.
  8. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: étape 8, image 1 de 1
    • Gently remove the old Wi-Fi card from the device.
Jeryn Fast
Membre depuis le 04/12/22
421 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Beck Spring 2022 Membre de l'équipe IUPUI, Team 1-1, Beck Spring 2022
IUPUI-BECK-S22S1G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 266
