Aller au contenu principal
Lenovo IdeaPad Z570 Charging Port Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Z570 Charging Port Replacement, Battery: étape 1, image 1 de 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Charging Port Replacement: étape 2, image 1 de 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Charging Port Replacement: étape 3, image 1 de 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Charging Port Replacement: étape 4, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 4, image 2 de 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Charging Port Replacement, Disc Drive: étape 5, image 1 de 1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Charging Port Replacement: étape 6, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 6, image 2 de 2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Charging Port Replacement: étape 7, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 7, image 2 de 2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Charging Port Replacement: étape 8, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 8, image 2 de 2
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: étape 9, image 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: étape 9, image 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: étape 9, image 3 de 3
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Charging Port Replacement: étape 10, image 1 de 1
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Charging Port Replacement: étape 11, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 11, image 2 de 2
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Charging Port Replacement: étape 12, image 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: étape 12, image 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: étape 12, image 3 de 3
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Charging Port Replacement: étape 13, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 13, image 2 de 2
    • Pull the keyboard out from the terminal block.
  14. Lenovo IdeaPad Z570 Charging Port Replacement, Charging Port: étape 14, image 1 de 1
    • Place the laptop on the backside with the battery facing away from you.
    • Remove the eleven 7 mm screws located around the edge of the backside of the laptop using the Phillips #0 screwdriver.
  15. Lenovo IdeaPad Z570 Charging Port Replacement: étape 15, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 15, image 2 de 2
    • Remove the two 3 mm screws located in the battery slot using the Phillips #0 screwdriver.
    • Orientate the laptop back to its original position.
  16. Lenovo IdeaPad Z570 Charging Port Replacement: étape 16, image 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: étape 16, image 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: étape 16, image 3 de 3
    • There are three connection strips similar to the one in guide three.
    • Remove the three connection strips in the same manner as the keyboard replacement guide.
  17. Lenovo IdeaPad Z570 Charging Port Replacement: étape 17, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 17, image 2 de 2
    • Remove the two 7mm screws found on the right side of the silver plating on the laptop using the Phillips #0 screwdriver.
  18. Lenovo IdeaPad Z570 Charging Port Replacement: étape 18, image 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: étape 18, image 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: étape 18, image 3 de 3
    • Wedge the opening tool between the ethernet jack and the speaker to pry of the front plate of the laptop.
  19. Lenovo IdeaPad Z570 Charging Port Replacement: étape 19, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 19, image 2 de 2
    • Remove the one 7 mm screw located at the top left corner of the laptop near the charging port using the Phillips #0 screwdriver.
  20. Lenovo IdeaPad Z570 Charging Port Replacement: étape 20, image 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: étape 20, image 2 de 2
    • There are two connection terminals on the upper right hand corner of the fan.
    • Remove the connection terminal marked with a blue stripe.
  21. Lenovo IdeaPad Z570 Charging Port Replacement: étape 21, image 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: étape 21, image 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: étape 21, image 3 de 3
    • Lift the metal plate enough to wedge your index finger and thumb to grip the charger port.
    • Remove the charging port from the device.
Mya DeSantos
Membre depuis le 03/18/19
318 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G6, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 36
Total : 1,652
