Aller au contenu principal
Lenovo IdeaPad Z570 Keyboard Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Z570 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Keyboard Replacement: étape 2, image 1 de 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Keyboard Replacement: étape 3, image 1 de 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Keyboard Replacement: étape 4, image 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: étape 4, image 2 de 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Keyboard Replacement, Disc Drive: étape 5, image 1 de 1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Keyboard Replacement: étape 6, image 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: étape 6, image 2 de 2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Keyboard Replacement: étape 7, image 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: étape 7, image 2 de 2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Keyboard Replacement: étape 8, image 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: étape 8, image 2 de 2
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: étape 9, image 1 de 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: étape 9, image 2 de 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: étape 9, image 3 de 3
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Keyboard Replacement: étape 10, image 1 de 1
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Keyboard Replacement: étape 11, image 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: étape 11, image 2 de 2
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Keyboard Replacement: étape 12, image 1 de 3 Lenovo IdeaPad Z570 Keyboard Replacement: étape 12, image 2 de 3 Lenovo IdeaPad Z570 Keyboard Replacement: étape 12, image 3 de 3
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Keyboard Replacement: étape 13, image 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: étape 13, image 2 de 2
    • Pull the keyboard out from the terminal block.
2 autres ont terminé cette réparation.
Mya DeSantos
Membre depuis le 03/18/19
318 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G6, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 28
Total : 1,189
