Aller au contenu principal
Lenovo IdeaPad Z570 Screen Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaPad Z570 Screen Replacement, Battery: étape 1, image 1 de 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Screen Replacement: étape 2, image 1 de 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Screen Replacement: étape 3, image 1 de 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Screen Replacement: étape 4, image 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: étape 4, image 2 de 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Screen Replacement, Screen: étape 5, image 1 de 1
    • Open up the laptop with the screen facing you.
  6. Lenovo IdeaPad Z570 Screen Replacement: étape 6, image 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: étape 6, image 2 de 2
    • Remove the two rubber square screw covers located in the left and right lower hand corners of the screen.
  7. Lenovo IdeaPad Z570 Screen Replacement: étape 7, image 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: étape 7, image 2 de 2
    • Unscrew the two 4 mm screws behind the two rubber screw covers using the Phillips #0 screwdriver.
  8. Lenovo IdeaPad Z570 Screen Replacement: étape 8, image 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: étape 8, image 2 de 2
    • Using the opening tool, pry open the plastic screen border, beginning with the upper right hand corner then working your way around.
    • Pry off the screen cover from the device.
  9. Lenovo IdeaPad Z570 Screen Replacement: étape 9, image 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: étape 9, image 2 de 2
    • Remove the two 2 mm screws at the top two corners of the screen using the Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Screen Replacement: étape 10, image 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: étape 10, image 2 de 2
    • Loosen the four 2 mm screws located at the bottom corners of the screen.
    • These screws cannot be removed.
  11. Lenovo IdeaPad Z570 Screen Replacement: étape 11, image 1 de 3 Lenovo IdeaPad Z570 Screen Replacement: étape 11, image 2 de 3 Lenovo IdeaPad Z570 Screen Replacement: étape 11, image 3 de 3
    • Tilt the screen forward gently.
    • Remove four 3 mm screws on the sides of the brackets holding the screen (two on the left side and two on the right side) using the Phillips #0 screwdriver.
  12. Lenovo IdeaPad Z570 Screen Replacement: étape 12, image 1 de 1
    • Lean the LCD screen face-down on the keyboard gently.
  13. Lenovo IdeaPad Z570 Screen Replacement: étape 13, image 1 de 3 Lenovo IdeaPad Z570 Screen Replacement: étape 13, image 2 de 3 Lenovo IdeaPad Z570 Screen Replacement: étape 13, image 3 de 3
    • Gently remove the adhesive covering surrounding the wires that’s connected to the back of the screen.
    • Disconnect the plug from the connection terminal.
    • Remove the screen completely.
Daniel Lopes
Membre depuis le 03/08/19
610 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G6, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 28
Total : 1,074
