Aller au contenu principal
Lenovo IdeaTab A1000L Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaTab A1000L Battery Replacement, Battery: étape 1, image 1 de 3 Lenovo IdeaTab A1000L Battery Replacement, Battery: étape 1, image 2 de 3 Lenovo IdeaTab A1000L Battery Replacement, Battery: étape 1, image 3 de 3
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Battery Replacement: étape 2, image 1 de 3 Lenovo IdeaTab A1000L Battery Replacement: étape 2, image 2 de 3 Lenovo IdeaTab A1000L Battery Replacement: étape 2, image 3 de 3
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next, with the same screwdriver, remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  3. Lenovo IdeaTab A1000L Battery Replacement: étape 3, image 1 de 3 Lenovo IdeaTab A1000L Battery Replacement: étape 3, image 2 de 3 Lenovo IdeaTab A1000L Battery Replacement: étape 3, image 3 de 3
    • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and pry it up.
    • Again, use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
    • Gently place the battery aside.
10 autres ont terminé cette réparation.
Peter Newell
Membre depuis le 04/15/14
627 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-21, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 7-21, Regan Spring 2014
CPSU-REGAN-S14S7G21
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 22,984
