Aller au contenu principal
Lenovo IdeaTab A2109 Battery Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaTab A2109 Battery Replacement, Battery: étape 1, image 1 de 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Battery Replacement: étape 2, image 1 de 2 Lenovo IdeaTab A2109 Battery Replacement: étape 2, image 2 de 2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 Battery Replacement: étape 3, image 1 de 2 Lenovo IdeaTab A2109 Battery Replacement: étape 3, image 2 de 2
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 Battery Replacement: étape 4, image 1 de 2 Lenovo IdeaTab A2109 Battery Replacement: étape 4, image 2 de 2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 Battery Replacement: étape 5, image 1 de 2 Lenovo IdeaTab A2109 Battery Replacement: étape 5, image 2 de 2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
9 autres ont terminé cette réparation.
Kyle
Membre depuis le 04/22/14
581 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-19, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 membres
15 tutoriels rédigés
Un commentaire
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
FilAm Harley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 9
Total : 8,265
