Aller au contenu principal
Lenovo IdeaTab A2109 Digital Board Replacement
Ce dont vous avez besoin
  1. Lenovo IdeaTab A2109 Digital Board Replacement, Digital Board: étape 1, image 1 de 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller plastic cover that runs across the top of the device.
    • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Digital Board Replacement: étape 2, image 1 de 2 Lenovo IdeaTab A2109 Digital Board Replacement: étape 2, image 2 de 2
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Digital Board Replacement: étape 3, image 1 de 3 Lenovo IdeaTab A2109 Digital Board Replacement: étape 3, image 2 de 3 Lenovo IdeaTab A2109 Digital Board Replacement: étape 3, image 3 de 3
    • Once it is unscrewed, remove the rear cover
    • This may take a little force to get off but with enough force it should pop right off
    • Use a blue opening tool to pry it open
    • Slide the tool to one corner then grab another tool and slide it to the opposite corner
    • Pull the cover up and it will come off
  4. Lenovo IdeaTab A2109 Digital Board Replacement: étape 4, image 1 de 2 Lenovo IdeaTab A2109 Digital Board Replacement: étape 4, image 2 de 2
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  5. Lenovo IdeaTab A2109 Digital Board Replacement: étape 5, image 1 de 2 Lenovo IdeaTab A2109 Digital Board Replacement: étape 5, image 2 de 2
    • M5.3 x 1.75 mm #00 phillips screws (silver)
  6. Lenovo IdeaTab A2109 Digital Board Replacement: étape 6, image 1 de 1
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
4 autres ont terminé cette réparation.
Brian
Membre depuis le 04/22/14
565 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-19, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 3,026
