Aller au contenu principal
Lenovo Ideapad 110S-11IBR Touchpad Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Battery: étape 1, image 1 de 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 2, image 1 de 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 2, image 2 de 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 3, image 1 de 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 3, image 2 de 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 4, image 1 de 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 5, image 1 de 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 5, image 2 de 2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Touchpad: étape 6, image 1 de 1
    • Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
  7. Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 7, image 1 de 1
    • Remove the clicker assembly.
  8. Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 8, image 1 de 2 Lenovo Ideapad 110S-11IBR Touchpad Replacement: étape 8, image 2 de 2
    • Use a plastic opening tool to remove the touch pad.
    • Time must be taken to work the adhesive without causing damage to the touch pad.
Samaa Aldar
Membre depuis le 04/06/19
181 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S11-G11, Wilson Spring 2019 Membre de l'équipe IUPUI, Team S11-G11, Wilson Spring 2019
IUPUI-WILSON-S19S11G11
2 membres
6 tutoriels rédigés
Un commentaire
i appreciate the tear down. I would like to see the screws that came out of the holes instead of empty screw holes though.
daldal - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 1,308
