Aller au contenu principal
Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, Back Cover: étape 1, image 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement: étape 2, image 1 de 1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, USB Daughterboard: étape 3, image 1 de 2 Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, USB Daughterboard: étape 3, image 2 de 2
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
  4. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement: étape 4, image 1 de 1
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 745
