Aller au contenu principal
Lenovo Ideapad 120s-14iSp Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad 120s-14iSp Motherboard Replacement, Back Cover: étape 1, image 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo Ideapad 120s-14iSp Motherboard Replacement: étape 2, image 1 de 1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo Ideapad 120s-14iSp Motherboard Replacement, USB Daughterboard: étape 3, image 1 de 2 Lenovo Ideapad 120s-14iSp Motherboard Replacement, USB Daughterboard: étape 3, image 2 de 2
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
  4. Lenovo Ideapad 120s-14iSp Motherboard Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
  5. Lenovo Ideapad 120s-14iSp Motherboard Replacement, Motherboard: étape 5, image 1 de 3 Lenovo Ideapad 120s-14iSp Motherboard Replacement, Motherboard: étape 5, image 2 de 3 Lenovo Ideapad 120s-14iSp Motherboard Replacement, Motherboard: étape 5, image 3 de 3
    • Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
    • Pull on the plastic film to remove the display connection cable.
  6. Lenovo Ideapad 120s-14iSp Motherboard Replacement: étape 6, image 1 de 1
    J'achète
    • Using tweezers, disconnect the connections for the right speaker.
    • Using tweezers, disconnect the connections for the battery.
    • Using tweezers, disconnect the connections for the CMOS battery.
  7. Lenovo Ideapad 120s-14iSp Motherboard Replacement: étape 7, image 1 de 1
    • Remove the wireless card by disconnecting the two antenna cables and removing the 2.5 mm Phillips #0 screw.
  8. Lenovo Ideapad 120s-14iSp Motherboard Replacement: étape 8, image 1 de 2 Lenovo Ideapad 120s-14iSp Motherboard Replacement: étape 8, image 2 de 2
    • Remove seven 2.5 mm Phillips #0 screws from the motherboard.
    • Slide the motherboard out of the laptop chassis.
4 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 25
Total : 2,743
