Aller au contenu principal
Lenovo Ideapad Flex 15 Bottom Panel Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: étape 1, image 1 de 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: étape 1, image 2 de 2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 2, image 1 de 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 2, image 2 de 2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 3, image 1 de 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 3, image 2 de 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 3, image 3 de 3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 4, image 1 de 1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 5, image 1 de 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 5, image 2 de 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 5, image 3 de 3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 6, image 1 de 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement: étape 6, image 2 de 2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
3 autres ont terminé cette réparation.
Brent
Membre depuis le 03/04/16
804 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 Membre de l'équipe UMass Dartmouth, Team 6-6, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 2,878
