Introduction
If you need to replace or reinstall the USB ports on your Lenovo Ideapad Flex 15, this guide will walk you through the process.
Ce dont vous avez besoin
Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
Locate the large blue circuit board on the leftmost side of the Flex 15.
This board is connected in two ways, by both a screw and a ribbon cable.
The large black ribbon cable is attached to a header. With a blue opening tool, flip up the ZIF (zero insertion force) connector, then pry the header from a 0 degree angle to a 90 degree angle. Be sure not to snap the header while doing it, it is very delicate.
Once the ribbon cable is freed, gently pull it out of the header.
