Aller au contenu principal
Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement, Back Panel: étape 1, image 1 de 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement: étape 2, image 1 de 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement, Cooling Fan: étape 4, image 1 de 2 Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement, Cooling Fan: étape 4, image 2 de 2
    • Remove the three 5mm screws using the T5 Torx Screwdriver.
  5. Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement: étape 5, image 1 de 2 Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement: étape 5, image 2 de 2
    • Pull black wire and gray wire away from cooling fan clips using the tweezers.
  6. Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement: étape 6, image 1 de 3 Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement: étape 6, image 2 de 3 Lenovo Ideapad Flex 4-1570 Cooling Fan Replacement: étape 6, image 3 de 3
    • Pull out the cooling fan from where it is attached and pull it up until you see where the wire is attached to the motherboard. Using the iFixit Opening Tools, detach the connector.
Isaiah Vang
Membre depuis le 10/04/18
669 Réputation
6 tutoriels rédigés
Équipe
UW Stout, Team S6-G6, Ogden Fall 2018 Membre de l'équipe UW Stout, Team S6-G6, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G6
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 355
