Aller au contenu principal
Lenovo Ideapad S415 Touch Hard Drive Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad S415 Touch Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 2, image 1 de 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 3, image 1 de 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 4, image 1 de 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 5, image 1 de 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: étape 6, image 1 de 2 Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: étape 6, image 2 de 2
    • Locate the five black screws on the back.
    • Use a Phillips #0 screwdriver to remove all five black 6 mm screws.
  7. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 7, image 1 de 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 7, image 2 de 2
    • Locate the three silver screws underneath the battery.
    • Use the Phillips #0 screwdriver to remove all three 4 mm screws.
  8. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 8, image 1 de 3 Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 8, image 2 de 3 Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 8, image 3 de 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stopper with your hands.
    • Use the Phillips #0 screwdriver to remove the 6 mm screws underneath all four stoppers.
  9. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 9, image 1 de 1
    • Open the laptop carefully.
  10. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 10, image 1 de 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 10, image 2 de 2
    • Locate the hard drive.
    • Use the Phillips #0 screwdriver to remove the two 4 mm screws that are holding the hard drive in place.
  11. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 11, image 1 de 1
    • The hard drive is now removed from the laptop.
  12. Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 12, image 1 de 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: étape 12, image 2 de 2
    • Once the hard drive is removed, locate the four screws that hold the metal frame to the hard drive.
    • Use the Phillips #0 screwdriver to remove the 4 mm silver screws on all sides.
Casey Zhang
Membre depuis le 02/06/19
315 Réputation
2 tutoriels rédigés
Équipe
UC Davis, Team S20-G5, Lore Winter 2019 Membre de l'équipe UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 478
