Aller au contenu principal
Lenovo Ideapad S415 Touch RAM Replacement
Ce dont vous avez besoin
  1. Lenovo Ideapad S415 Touch RAM Replacement, Battery: étape 1, image 1 de 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch RAM Replacement: étape 2, image 1 de 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch RAM Replacement: étape 3, image 1 de 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch RAM Replacement: étape 4, image 1 de 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch RAM Replacement: étape 5, image 1 de 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch RAM Replacement, RAM: étape 6, image 1 de 2 Lenovo Ideapad S415 Touch RAM Replacement, RAM: étape 6, image 2 de 2
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five screws.
  7. Lenovo Ideapad S415 Touch RAM Replacement: étape 7, image 1 de 2 Lenovo Ideapad S415 Touch RAM Replacement: étape 7, image 2 de 2
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Use the Phillips #0 screwdriver to remove all three screws.
  8. Lenovo Ideapad S415 Touch RAM Replacement: étape 8, image 1 de 3 Lenovo Ideapad S415 Touch RAM Replacement: étape 8, image 2 de 3 Lenovo Ideapad S415 Touch RAM Replacement: étape 8, image 3 de 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your hands.
  9. Lenovo Ideapad S415 Touch RAM Replacement: étape 9, image 1 de 3 Lenovo Ideapad S415 Touch RAM Replacement: étape 9, image 2 de 3 Lenovo Ideapad S415 Touch RAM Replacement: étape 9, image 3 de 3
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch RAM Replacement: étape 10, image 1 de 2 Lenovo Ideapad S415 Touch RAM Replacement: étape 10, image 2 de 2
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch RAM Replacement: étape 11, image 1 de 3 Lenovo Ideapad S415 Touch RAM Replacement: étape 11, image 2 de 3 Lenovo Ideapad S415 Touch RAM Replacement: étape 11, image 3 de 3
    • Locate the RAM.
    • Using your hands gently push up on the two silver clips located on both ends of the RAM.
    • The RAM will spring out. Gently pull it out of the slot.
    • Do not touch the top yellow part of the RAM as this will cause damage.
Alexandria
Membre depuis le 02/05/19
363 Réputation
2 tutoriels rédigés
Équipe
UC Davis, Team S20-G5, Lore Winter 2019 Membre de l'équipe UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 740
