Introduction
If your trackpad stops working or has any performance issues, you can follow this guide to remove and replace it.
Ce dont vous avez besoin
Begin by turning your closed laptop so that you are looking at the bottom panel.
Locate the battery in the bottom right corner.
Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
Locate the cable connecting to the battery. It is located at the top-center of the battery.
Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
2 autres ont terminé cette réparation.
