Aller au contenu principal
Lenovo Legion Y520-15IKBN Fan Replacement
Ce dont vous avez besoin
  1. Lenovo Legion Y520-15IKBN Fan Replacement, Base Panel: étape 1, image 1 de 1
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Fan Replacement: étape 2, image 1 de 1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Fan Replacement, Fan: étape 3, image 1 de 3 Lenovo Legion Y520-15IKBN Fan Replacement, Fan: étape 3, image 2 de 3 Lenovo Legion Y520-15IKBN Fan Replacement, Fan: étape 3, image 3 de 3
    • There is a piece of plastic covering part of the RAM and the fan. You will need to remove this to get to the fan.
    • Unplug the battery then, you will need to remove the four 4mm screws around the fan using a Phillips #00 screwdriver.
  4. Lenovo Legion Y520-15IKBN Fan Replacement: étape 4, image 1 de 3 Lenovo Legion Y520-15IKBN Fan Replacement: étape 4, image 2 de 3 Lenovo Legion Y520-15IKBN Fan Replacement: étape 4, image 3 de 3
    • Unscrew all the screws then unplug the wires connected to the fan.
    • Once all the wires are unplugged from the fan, move the wires aside to get the fan.
  5. Lenovo Legion Y520-15IKBN Fan Replacement: étape 5, image 1 de 3 Lenovo Legion Y520-15IKBN Fan Replacement: étape 5, image 2 de 3 Lenovo Legion Y520-15IKBN Fan Replacement: étape 5, image 3 de 3
    • Lift the fan out of the laptop body.
9 autres ont terminé cette réparation.
Emilee
Membre depuis le 10/04/18
262 Réputation
1 tutoriel rédigé
Équipe
3 commentaires
Superb guide. thank you random citizen for creating this guide
Fikri Nur Nafi - Réponse
Do I need to remove the fan if I want to clean it or add oil?
Ziro Hutt - Réponse
Is there a way to open the fan to clean the dust from the blade ?
Apalagi08 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 32
Total : 7,291
