Aller au contenu principal
Lenovo Legion Y530-15ICH Fan Replacement
Ce dont vous avez besoin
  1. Lenovo Legion Y530-15ICH Fan Replacement, Back Cover: étape 1, image 1 de 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Fan Replacement: étape 2, image 1 de 2 Lenovo Legion Y530-15ICH Fan Replacement: étape 2, image 2 de 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Fan Replacement, Fan: étape 3, image 1 de 2 Lenovo Legion Y530-15ICH Fan Replacement, Fan: étape 3, image 2 de 2
    • Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
    • Remove the plastic covering after the screws have been loosened.
    • Spring screws will stay attached to the cover.
  4. Lenovo Legion Y530-15ICH Fan Replacement: étape 4, image 1 de 1
    • Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
  5. Lenovo Legion Y530-15ICH Fan Replacement: étape 5, image 1 de 1
    • Unplug the wires connecting the two fans to the motherboard.
    • When doing this, tug carefully from side to side.
  6. Lenovo Legion Y530-15ICH Fan Replacement: étape 6, image 1 de 2 Lenovo Legion Y530-15ICH Fan Replacement: étape 6, image 2 de 2
    • Lift the fans out of their positions and remove them from the device.
6 autres ont terminé cette réparation.
Kaylie Klausing
Membre depuis le 02/07/20
776 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S7-G1, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 membres
12 tutoriels rédigés
4 commentaires
Thank you! Very clear and well photographed :)
Daniel Perez - Réponse
Any recommended stores for the replacement fans?
Ivan Ramljak - Réponse
Worked like a charm, thank you!!
Skyler Boyle - Réponse
where can i get a good replacement please
peters pelumi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 33
30 derniers jours : 159
Total : 12,665
