Aller au contenu principal
Lenovo N23 Chromebook Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo N23 Chromebook Wi-Fi Card Replacement, Battery: étape 1, image 1 de 2 Lenovo N23 Chromebook Wi-Fi Card Replacement, Battery: étape 1, image 2 de 2
    • Before starting, make sure that the laptop is powered off and completely unplugged from the charger.
    • Remove the eight 6.0 mm screws holding the back into place using a Phillips #0 screwdriver.
  2. Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Flip the device over.
    • Slide a plastic opening tool between the back cover and keyboard.
    • Carefully pry upwards until you hear a click.
    • Following the seam, slide the opening tool all the way around the front cover, prying upwards occasionally until the keyboard and trackpad are loose from the back cover.
    • Lift the keyboard panel up to reveal the internals.
    • Don't lift the keyboard panel too violently, as there is still a cable attachment to the motherboard.
  3. Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 3, image 1 de 3 Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 3, image 2 de 3 Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 3, image 3 de 3
    • You can now access the internals of the computer.
    • Disconnect the two ribbon cables that connect from the motherboard to the front cover.
    • Using the iFixit opening tool, flip up the black tab holding keyboard ribbon cable and then pull the cable out.
    • Using the opening tool, flip the white tab holding the mouse ribbon cable and then pull the cable out.
  4. Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 4, image 1 de 2 Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Lift the keyboard panel from the case and fully remove it from the device.
  5. Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the battery in place.
  6. Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 6, image 1 de 3 Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 6, image 2 de 3 Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 6, image 3 de 3
    • Disconnect the battery cable using a plastic opening tool by pulling on the black plastic lip.
    • Lift the battery out of the laptop.
  7. Lenovo N23 Chromebook Wi-Fi Card Replacement, Wifi Card: étape 7, image 1 de 3 Lenovo N23 Chromebook Wi-Fi Card Replacement, Wifi Card: étape 7, image 2 de 3 Lenovo N23 Chromebook Wi-Fi Card Replacement, Wifi Card: étape 7, image 3 de 3
    • Use a plastic opening tool to disconnect the two coaxial cables from the Wi-Fi card.
    • Tuck the two wires out of the way.
  8. Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 8, image 1 de 3 Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 8, image 2 de 3 Lenovo N23 Chromebook Wi-Fi Card Replacement: étape 8, image 3 de 3
    • Remove the single 3.0 mm Phillips #1 screw holding the Wi-Fi card using a Phillips #1 screwdriver.
    • Using your hands, carefully pull the Wi-Fi card sideways out of the port on the motherboard.
Jarod Ostir
Membre depuis le 02/19/21
465 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 23
Total : 407
