Introduction
The screen may become unresponsive in your Lenovo S20-30 netbook requiring you to replace the display monitor. Displays are around $60 depending on where you buy it. Before replacing your display monitor turn off the computer to avoid risk of electric shock. There are many components to your monitor so it is common for parts to break or disconnect. By following these steps, you can successfully achieve detaching the old display monitor to reassemble the new one.
Ce dont vous avez besoin
Vidéo d'introduction
Pry open the frame using a plastic opening tool.
Pull frame upward to remove it.
2 autres ont terminé cette réparation.
